Mike Henry
- Aug 8, 2009
- 107
- 27
Thanks Rich - still learning something new every day. Looks like I'll be picking up some carbide spot drills in larger diameters.
So, who's going to post the next topic?
I like it - especially boring very small diameter holes. My smallest boring cutter is 6mm, and I certainly don't feel comfortable using it... deflection, deflection, deflection... So, Goldstar, are you going to start a new thread, or should I?So moving a little, what about the other boring subject-- bore-ing?
So you are unable bore a hole smaller than 'under 3mm'? I lost my stuff in a wintr's storm that woukkd drill perhaps 1.5mm.I like it - especially boring very small diameter holes. My smallest boring cutter is 6mm, and I certainly don't feel comfortable using it... deflection, deflection, deflection... So, Goldstar, are you going to start a new thread, or should I?
Thanks to everyone who contributed to this - most definitely an excellent "knowledge base". We need more of this type of discussion on other "common" workshop techniques... although we could probably skip the "how to hammer a nail into a piece of wood"
What is your preferred method of drilling deep holes as accurately as possible using a lathe? I have been thinking about this for many years, trying to decide the "best" way to drill a reasonably large hole (say 16mm diameter...) for a depth of (say) 10 x diameter into steel. In your opinion (for hobbyists, and not using specialised through lubricated gun drills, etc.):
Using the second method one would make chip evacuation easier, and put less strain on the drill (both helping to increase the accuracy of the hole), but each successive drill bit would be "guided" only on the outer rim of it's cutting edges, which would make it easier to go off track. The first method would guide over the drill bit's full cutting edges, thus keeping the drill centered, but would create a much larger amount of chips to be evacuated, which would tend to push the drill off center, thus requiring more "peck drilling"...
- would it be better to drill a small diameter pilot hole (say 4mm dia.) as deep as it can go, and then only drilling once using the final size drill, or
- would it be better to use a succession of increasing sized drills (say 4mm, then 8mm, then 10mm, 12mm, 14mm and finally 16mm
I normally use the first method, but would appreciate your comments on this. Also, please feel free to comment on any other method you use, and also on drill bit types, twist rates, using a drill chuck vs using Morse tapered drills mounted directly in the tailstock, etc. etc.
Thanks for your comments
Hennie
SmithDoor is correct. My preference, after the spot or c’drill is to use a drill that is about the diameter of the web thickness of the larger drill 1/2” and larger, then bore to establish center line and ream to size.
My self in drilling on lathe is.
1) Center drill.
2) drill smaller hole in most cases.
3) larger drill still under size.
4) use a boring bar so hole turn true.
5) If have a Reamer then ream to size or bore to size.
