Hello everybody,
another setup, that no one asked me to post. I post it anyway. Presumably only works on blue machines. (sorry for the owners of green machines
The hypothetical problem at hand. Cutting a disc from the 20mm left over of 1" rod. (I made the left over extra to be able to make the fotos)
I put the 20mm long piece into my ER40 collet block only about 5mm length are in the collet.
EDIT: In a post below BaronJ advises to be careful with using the ER collet only in the front, the advise is to put at least some piece of the same diameter in the rear end of the collet to prevent it from beeing uneven compressed.
I put my ER40 collet block into the machines clamping arrangement.
I cut off a small piece for demonstration purpose only.
The ER collet clamps at the very front quite O.K. For a saw cut good enough.
For milling or turning I would not trust it too much.
I hope someone finds it useful. To be able to find the small piece in all the swarf, the mod that BaronJ made with the Al block maybe a good add on. (not for the blue machine, because it has a chip tray under the slot to collect some swarf)
Greetings Timo
