Richard Carlstedt
Perhaps this has been said before, but let me rephrase the commentary that talks about rubber tires and crowned wheels.
There are two kinds of Bandsaws - and they are not the same- you must realize the difference !
The conventional Vertical Bandsaw ( that we mostly see ) has a crowned wheel and rubber tires. This saw uses the crowned wheel to center the blade and the rubber tires allow various width blades as the rubber does not destroy the tooth set and the "crown " centers the blades. The guide rollers or solid guides are adjusted to keep the blade in "its crowned wheel" setting and prevent forces to push the blade off the "crowned center" . When you replace the blade, the guides are opened up and the blade runs till stabilized , AND then the guides ( sides and rear) are brought in to support that width blade AT that position. Please note , the saw will cut without the guides (!) but the your forces will push the blade off the wheel
The standard Horizontal Bandsaw , Which I will call a "Cutoff Bandsaw" is an entirely different saw in setup and use , and requires one to know about the "Neutral Axis" of the blade ( Critical ) .
There are a few other issues to deal with , but lets say the wheels are aligned and that you have replaced the blade and all guides are removed . Now I want you to take a Crescent wrench ( adjustable spanner) and clamp it on the blade -which is now 45 degrees from vertical- and rotate the blade so it is vertical . You have now rotated the blade about it's neutral axis ! That means even though the blade is stretched by the wheels , you have stretched the blades leading and trailing edges, but the middle of the blade ( 1/4" in on a 1/2" blade) -Its neutral axis - is not stretched !
This is critical to understand tracking.
Now the problem with these saws, and I have seen it in many of them , is that the guides must do this and they don't . If in turning the blade 45 degrees, they stretch or move the neutral axis, you are forever plagued with , non tracking, breaking and short life. If you take a used blade out and it is conical, you have stretched the blade because of the guides. I have machined the guides on several saws to allow them to track the neutral axis. it is amazing to me the number of saws that "bend" the proper track and that the saw makers do not make the blade guides properly .
As mentioned, there are other issues with a Cutoff saw that need to be addressed, but without neutral axis control, all are destined to fail
Rich
PS The Vertical bandsaw never has a Neutral axis issue as the blade is not twisted
Rich
