Thank you for the information,as for the gears that drive the pumps and magneto,did you seal them in anyway and lubricate them or are they exposed to the elements?Sealing the bearing is a problem i resolved this on my engine by fitting seald bearings they were slightly wider so i remade the housings also i made the front housing and propeler boss all in one as instructed by Mike Cole a prolific model engine builder
No i did not seal the gears left them open there is plenty of oil about when you run the engine as you will find outThank you for the information,as for the gears that drive the pumps and magneto,did you seal them in anyway and lubricate them or are they exposed to the elements?
Haha I'm sure,thank you for your help!! I may make a few modifications!No i did not seal the gears left them open there is plenty of oil about when you run the engine as you will find out
yes i would say so, great fun was had drilling those holes i am thinking i drilled 1mm holes the same as the circle of holes in the cylinder base (fuel transfer ports)Oh this are problems for later.
Is it possible to fly a light model with the engine?
In inventor I have seen that the piston open the holes in the cylinder very small. If there is a little difference between the holes, does it run too. There are 0,5 mm Max. The drill runs a little bit up and down during boring the holes. I hope you could understand my English .
this is my engine running i did not intend to fly it it is mounted on a Gun carriage as in a picture taken from Andrew Naham,s book, you can see additionl tank that i use fuel/oil when i run it to be removed when in Exhibition modeHas Someone a video from running the engine. I find only the video from Ron.
Which propeller can be used and what is the Umin from the engine.
Yes there are challenge,s it will be worth it when completed i did not attempt the woodruf keys on a taper i followed the full size method and cut straight keysThank you for this video. It looks very great. I hope my engine become ready .
There are a lot of problems . One are the key ways . There I must look for another possibility . I couldn’t produce them.
Thank you for that What you can,t experience from the video is the smell of Castrol R oil but as with the full size total loss oil it is the messiest engine you could wish to run but great funKitson, that is really impressive - so smooth running. Well done!!!
