With the correct choice of airframe, it is possible to fly with almost any engine. A slower flying aircraft with large wing area is more efficient and can carry a heavy engine with low power. The Wright Brothers had 12 HP from an 82 kg engine.
the bearings i used were of the rubber sealed type as i found it impossible to effectivley seal the rear bearing as in the Chenery drawings it meant a slight modification to the housing i think around 1/32" deeper?
Yes I will check my paperwork the bearings are stock items over here the only difference is the width Od & bore the same I will be in touch with regarding this matter shortly
