What you need is a DC light (i.e. a car headlight with battery to keep things simple and cheap) chopped at the same frequency of the lathe. It can be a mechanical shutter like in a movies projector connected with the lathe spindle.
There are bold warnings printed on them to this effect.(mine certainly has).
I'm missing something What is the benefit of the strobe other than making a cool video to market your cutting tools?
I am not an experianced machinist in either application (wood, metal), though I have watched a strobe being used on a wood lathe several times and that was the explanation/reasoning I was given.Thanks for the explanation. So it is more of a wood lathe application that could also be used on a metal lathe.
My brother is a Woodturner (can't convince him to stop using that brown stuff)
He wants to have a strobe synced to his lathe (approx 50 - 2000 rpm).
Would an auto timing light work? If so, what to sync it? Hall effect sensor? How would one hook this up?
I'm at a loss with 'lectrical stuff.
Thanks for any suggestions
a timing light uses some kind of clamp sensor, there are a few types but my understanding is that they are all designed to measure current not voltage.
A timing light uses capacitive coupling. One side of the capacitor is the clamp, the other the HV wire. If you want to get awake (= get an electrical shock), simply touch the wire coming from the clamp. There should be at least something like 400 V. That's the voltage needed to ignite a xenon bulb (that are used in almost all timing lights).
Nick
if it was capacitive it would only need one and if the voltage drove a xenon bulb directly
I wrote "ignite". The cheap timing lights take off part of the high voltage and lead that to the ignition contact of the tube. That has nothing to do with the voltage for the bulb that makes the flash. A Xenon tube has 3 contacts, not just two.
Nick
