I have a weiss lathe http://www.weiss.com.cn/products/wmp250v.php and when i set some heavy cut the v belt drive starts slipping and eventually the spindle will almost stop turning. I know that the belt is slipping because while cutting the rev counter reduces speed drastically and after removing the back cover I noticed that the pulleys were very hot.
I was thinking to replace the pulleys with either larger v belt pulley or else replace then with toothed belt pulleys. Which one will be most adequate, the v belt will allow some slippage in case that bad things happen... any opinions please
Andrei
Andrei
