Lookin' good kvom. How will you be sealing the smoke box around the steam inlet pipe. Your "T" is also slightly different from Kozo's design.
I'd put a valve between the boiler and the check valve, that way if the check starts acting up while the boiler is under pressure you can close the valve and open the check. You might have one there already, I can't really make out the details there.
I considered that, but was advised to avoid any extra sources of turbulence in the water path that might "annoy" the injector. It will not be difficult to add one at a future date though.
