vcutajar
- Nov 6, 2011
- 862
- 168
This morning I was thinking of drilling the oil passageways in the crank but as I know that I work slowly and this afternoon I have to go to work I decided not to do the passageways.
I wanted to do something simple and decided to do the hole for the breather assembly in the rear crankcase. Marked the hole, fixed the casting to the angle plate and drilled and tapped for 6mm fine. As the surface in the area is round and tapered, I counterbored with an endmill 10mm so that the body of the breather will seat on a flat surface. Et voila finished. At least I did something today. This maching thing has become addictive. I need to do something, even if I sit down in front of the plans and plan something, at least I will not get withdrawal symptoms.
