I haven't been idle these last couple of days. I was making the engine supports so that it can stand on its own feet. I used a piece of aluminium flat bar that I had and milled it to size.
Yesterday I was looking at the two engine supports and was thinking that they look bland. I need to spruce them up a bit. Various ideas came to mind but the one which I sort of liked was to engrave the name of the engine on each support. Just one problem, actually BIG problem. I don't have CNC.
So I kept thinking about it and came up with a plan. I still do not know if it's going to work. Well if I do not like the end result I can face it off.
I went on the computer and wrote the name of the engine in a Word textbox roughly the size of the support. I used Arial as a font and played around with a font size till I got what I needed. I also made sure that all the letters used staight lines. Printed them, cut them and glued them to the aluminium (second photo).
Today, after work, went to do some experimenting with a piece of scrap aluminium. I used a 3mm ball nose mill and the groove on the left in the third photo is 0.5mm deep (for the large font size) and the one on the right is 0.25m deep for the smaller font size.
I did the straight vertical lines on one of them (forth photo). I had to take into account the thickness of the paper and glue. So for the large font I went to a depth of 0.6mm and for the other one 0.35mm. Tomorrow I hope to finish the grooving. The plan is to paint the grooves ( I was thinking red ) and then mill the face. At least that's the plan. We'll see if it works out.
