Tel---I haven't seen you mention it, but how is the compression? Are your valves sealing okay?---God, I hope they are!!!!----Brian
tel said:There's compression there Brian, the piston bounces back from it about a third of the way into the compression stroke with a light flick of the flywheel. I still have to fiddle with the spring on the inlet valve tho' - sans spring the valve sucks in perfectly, with spring it barely flickers, so a coil or two off the spring, methinks. The valves bedded down without any real problems, but, in the event, I couldn't find my closely guarded old double tin of compound, was stuck with using the fine end of a new tin of 'Pep' - worked that down until all trace of grittiness had disappeared then finished up with Brasso.
I agree I like that tank it is a really nice looking piece no matter where you place it.zeeprogrammer said:I like it with the tank away too.
It's an interesting item and should be seen.
