Snuck out into the workshop tonight and decided to make the port block up for a little wobbler I'm making. Cut off a strip of brass from a 6mm sheet I have, enough to make about 4 port blocks as I can see me needing more.
Cut one to size, squared it all up and cleaned it up. Filed a round groove for the cylinder, filed some nice rounded edges on the sides to match the existing one on the engine and then realised I forgot to drill the hole for the pivot.
Now I've got a nicely shaped and cleaned up object with round sides that I need to clamp in the vice and try and hold square to drill and tap it.
I'm pretty sure I will manage to do it but I'm kicking myself for not drilling it when it was a nice square block.
It's on this note I decided I had done enough for tonight and will try drilling it tomorrow.
