jpeter said:Because so many features are relaed to the cam position I decided to next drill the cam tunnel. Drilling a hole that deep has always been a challenge for me. I posted a querry on the forum about how to drill a deep hole straight and true. I got a lot of guesses but not much qualified real help. I googled the question and found whats referred to as a d-bit. Apparently it's the original gun drill. They're easy to make so I made one, drilled a test hole and was shocked at the results. I drilled a test hole in a 5 inch block with my homemade d-bit and got a hole that was accurate, straight and exited where it was supposed to. Try it, you'll like it. Just google d bit.
jpeter said:4-3/4 long. I missed you at the meeting. Heard you have the croup. Get well soon.
ROAD TRIP!!! ;Dstevehuckss396 said:OH Buddy!!
You should have never told me you have an EDM!!!
Indeed, but I was firmly knocking on wood when I typed that P)stevehuckss396 said:Famous last words!
That looks very interesting. I think I have the circuitry plan in one of my strictly IC issues. Different mode of thought, however, one project at a time.jpeter said:Building one is not to hard. Attached is a picture of mine setting in its storage place. Most any analog amp meter that goes to 5 amps will work. The big 50 watt resister could be replaced with automotive light bulbs. I used a motor starting capacitor from an old motor I already had and I had the variac although any source of dc volts most likely would work.
