Jack's Knucklehead Plans Feedback Wanted
Hi Jack
First off thanks for the free plans, way cool for you to share plans for free.i liked them so much I have started making the engine. So far so good I have done cylinders except for finish honing of cylinder bore crank is also complete working on outer rod now.
Attached a couple of photos
Thanks again I am really enjoying the project
SteveView attachment ImageUploadedByModel Engines1436326638.774809.jpgView attachment ImageUploadedByModel Engines1436326657.391349.jpgView attachment ImageUploadedByModel Engines1436326672.475654.jpg
I've also downloaded the plans, and would love to see a build log on this motor
Hint hint;);)
Hi Jack
SteveView attachment 77762View attachment 77763View attachment 77764
Hi Driller
You are welcome, I'm jealous, as I had to stop on all my fun to earn some money for them. I also have aquired a 3d printer, and learning to print precision parts, to print my engine in ABS plastic. the work that I see looks top notch work. (Awesome) When winter comes I hope to start again. I have so many projects. Sample of Crank Print.
Jack
Draw-Tech
    29.4 KB
Jack
Thanks Jack I didn't answer the question you were asking, I would certainly would have payed for plans 20 bucks would be a bargain price! I like that the materials list and part numbers and sources for parts are included
Steve
Jack
I do not see the valve guide details or the valve spring retainers, I'm sure I can fiqure them out but I thought I should mention it to you. I have started machining on heads and having a blast.
Thanks Steve
Jack
Thanks Steve
Hi Driller
Thought they were there. ???
Anyway here they are. Can't wait to see it, keep having fun.
Jack
Draw-Tech
View attachment Valve_Guide_Spring_Retainers.pdf
Hey Jack
Minor mistake on plans, the cylinder to crankcase mounting studs on plans call for 10-24 but the parts list calls out 8-32 which is what they should be. I had already drilled and tapped crankcase for the 10-24 before I noticed the error so I will make studs with both threads. Everything else is just awesome thanks
