can someon tell me how to remove to yellow question marks that keep showing on
Can't help you there.
Really interesting thread. Steve, have you calculated how much the parts, excluding circuit board, will cost for this?
Also, would be interested in knowing the maximum current this circuit can supply to the coil.
Finally, would this circuit work with points or a micro switch instead of a hall effect device?
Thx...
Chuck
Chuck:
Yes. A set of points or a switch connected to ground from the point labeled "OUT" now from the hall sensor would work just fine. No condenser (capacitor) or other parts required.
Perhaps Steve can draw that option for us.
Sage
I for one, enjoy the polite and respectful tone of this forum. Please eliminate the harsh and possibly antagonistic aspects of your posts, so the wisdom and knowledge can stand on their own. Thanks,Hi I don't know if it's because it makes you feel better or if your just enjoying
contradicting what I'm saying, but the end result is unfair to post readers.
I think that your bright enought to know that 6 inch of twisted pairs of wire will make noise in a circuit, a mechanical switch is even worst. I think that you also know that debouncing circuit ( to eliminate noise from a switch)is very popular, that using a matching capacitor is a common practice, then why not playing it safe with your buddy and tell them the truth.
I know and You know that a small capacitor across the switch or the point
wont affect the circuit. But you also know that if one was needed and was not install then problem will happen.
Steve, a small cap .01uf is like 4 cents put one in it's like inssurance to a good working circuit
Mosey
Thanks Les, Dsage, CHP, but it looks as if i'm moving on to plan B. The coil would not fire. I could see the voltage changing at the primary side but no spark. I am going to figure out another way. Even if the circuit didn't work for me, at least there is a good circuit that came out of it. I am sure it will help someone here. I'm sorry all your hard work added up to nothing but i'm sure if it were a standard coil the circuit would have worked just fine.
Steve, have you tried the coil with a standard auto condenser and points or some other kind of make / break? I know a regular auto ignition system with points and a coil won't work without the condenser.
Chuck
Hey Steve,
What's your plan B???
I have been working on plan B all along. Taking a break now, as I am tired of debugging a/d and interrupt code. Good news is I managed to create very scary voltages across large capacitors. Bad news is I smoked the two Pic16F690's I was using for development. :rant:I don't have one yet. Need to take a step back and figure out what I want to do.
Canadianhorsepower:
The input impedane of the circuit with the switch actvating the transistor directly is more or less about 680 ohms. It is unlikely there would be any "noise" on the switch leads large enough to bias the transistor on (requiring at least 10ma of current). But, like you said, small capacitors are cheap and a small .01uf wouldn't hurt.
(Now don't anyone criticize that statement because at some point the capacitor will slow down the transistor switching off time, but we won't go there).
There are lots of things that "could" be added to any circuit and most times you need to test these things on the bench, see where you have problems, and fix those problems.
Unfortunate that you chose to accuse me of lying to everyone that the capacitor IS need and I was somehow CHOOSING to not tell them about it.
Sage
But the spark that did it was glorious
