Making The Baseplate.
Nothing much to show here other than the circular (machine) polishing :-
Use a machined wooden dowel faced with a 3mm thick leather pad – glued on.
Choose a convenient size and pitch and work to a pattern.
In this case Ø16 @ 9mm pitch (my minimill’s leadscrew is 1.5mm) – I first ran down the middle – then offset 9mm from row to row and 4.5mm offset of the pitching on each following row – starting each row from the same end – repeat until your arm falls off. Then work outward on the other side mirror image.
I used coarse valve grinding paste, keep it wetted – using oil or water depending on what your paste base is - this is water based – but it tends to dry if you press hard – so I think oil based might be better here. A few seconds of moderate pressure per whorl is all it takes.
I've done this before and tried sandpaper disks, plain wooden dobs, rubber faces etc. etc. - the leather disk and grinding paste works the best.
Assembly & Fit Up.
Loosely assemble all the crank and gear parts.
Next assemble onto the base with the pinion gear correctly engaged – rotate crank, the big end pin should cycle horizontally in a straight line.
First go - the pinion was tight at the bottom and had lash at the top - clearly the two halves were out of line - I slackened off the nuts and re-tightened whilst rotating the gear - eventually rotated perfectly with practically zero lash.
Before fitting the cylinder assembly – check the centerline height of the big-end pin – it should be parallel to the base.
If it’s miles out then you probably don’t have the gear correctly aligned (like a tooth out).
It is possible, due to small angular errors in the orientation of the Annulus Gear (Detail -4-) or the Pinion Crank (Detail -12-) that the locus of motion is not parallel to the base - this will cause binding.
This can be corrected by shimming the Standoff Spacers (Detail -25-) to correct this with respect to the base or by adjusting the length of the Upright Spacers (Detail -26-) to set the cylinder to align with the locus of motion of the big-end pin. Or a combination of both.
My assembly ran true to the base and ran fine with the cylinder attached.
I had a tight spot near the end of the cylinder stroke which was cured by a little more honing of the cylinder bore at that end.
Other than that it ran first try – with no sealant on any of the joints or gland packing – so quite a bit of leakage.
The gland packing is PTFE plumbers tape twisted into a cord (use a drill) and then wound around the shaft and compressed to fit and seal by the gland nut.
Once happy with the running and fit up I assembled all the metal to metal surfaces with Loctite acid free silicone gasket maker (Loctite SI 5699 Grey).
Assembling the steam chest under the barrel hoops was a PITB but otherwise fine.
I then ran the engine at about 100 rpm for 4 hours – lubricating with ATF (automatic transmission fluid) – at the gears, conrod ends, valve stem and piston rod glands – stopping periodically to open the quick coupler and inject oil directly into the steam chest – to oil the piston internals and “D” valve.
It ticks over beautifully at slow speed and low pressure – being Ø20 x 48mm stroke it’s actually quite a powerful little engine.
I'll make a video once the presentation base is finished and post a link to the YouTube video of it running.
Presentation Base.
Finally a base :-
Chunk of wood cut from an ugly old plank of (what I think is) Kiaat.
Top Right – Use self adhesive printed sticker for “marking out” (my printer is more accurate than I am).
Mid Right – Drilling for M8 holddown Hex bolts.
Bottom Right – Milling the pocket.
Not shown – milling the moulding using router bits.
I used no stain and finished it with a polyurethane lacquer.
Still needs one more sand & another coat of lacquer.
I should have it finished & mounted and the video posted by Monday - then I'll post the plans.
Regards - Ken
