I do similar only I make allowance for and fit a 1/16" roll pin in each before cutting/grinding the cam pair just to be sure it's not going to go anywhere.
Do the machining, remove the pin, remove and harden the cam, then polish and refit with a new pin.
Don't trust loctite alone.
I agree with you, but in this case the gluing surface is a long cylinder
I cleaned shaft and hole with acetone and I use high strength Loctite for high temperatures (620)
In case of single cam I use roll pin
