- May 27, 2010
- 2,999
- 1,171
Don't forget to keep your rpm much lower than you would with high speed steel. If you provide a flute per tooth, even a straight slot, it may go deeper. It might have been just recutting its own chips because they couldn't get out of the way of the cutting edge. If you have 5-10 degrees relief there. Then I think that's all the tooth you need.
Hi Chris,
Got it. One Counterbore Spark Plug Hole done w/o case hardening but quite a few C/B resharpening with file. Redone relief angle to 15 degrees and c/b cuts beautifully. Mental Block removed. Second O/H will complete counterbore tomorrow 10 am.
Too bad I can't cancel order for CaseHardening Compound which will last me thru next life.
Thanks for the expert advice.
