- May 27, 2010
- 2,999
- 1,171
Hi Al,
I may have chewed off a big engine that I can cannot swallow and digest. Rough dimension sketch on crankcase blank with a 150 mm steel rule to give an idea how big the engine is. Did manage to face front/back of blank. Will band saw the outline for milling. Trying very hard not to rush and make unforgiveable mistakes. Crankcase is the base to grow and build engine block by block. The power table feed on the mini mill will cut out the hand cranking. With so much metal to endmill off,power feed sure came J.I.T. Gus will sit back with Power Feed doing all the cranking.
