The second phase of the intake manifold , i glued the manifold on a wood
base and took the references on the central hole ,drilled in the first phase
You can see a small displacement between the first and second phase.
I corrected the profile with file .
The challenge is to make internal holes and close them with welded aluminum caps ...
Flange grinding for exhaust and intake manifold
To get the 4 flanges all on the same plane without flatness errors, I mounted a 12,000 rpm spindle motor on the milling machine and with the grinding wheel I finished the planes
With help of my friend Iader we have fine-tuned the timing and carburetion
I used a small Rc model carburetor which , they told me , was more reliable than a self-built carburetor
