Hit and miss STEAM ENGINE????
CRANKSHAFT---
View attachment CRANKSHAFT FOR HIT AND MISS.PDF
If there is anything you don't understand (and there probably will be), please ask me and I will try to answer your questions.--There was a lot that I didn't understand when I started into this, and I think I have it pretty well figured out now.
A detail (doesn't need to be a dimensioned drawing) of the spring location/arrangement on the governor might be useful.
A bit more explanation as to how the cam works for the hit and miss cycle---
NOTE: THE FOLLOWING NOTE ON THIS DRAWING HAS AN ERROR ON IT---
VALVE ACTUATOR BUSHING-THIS IS SET SCREWED TO
THE CRANKSHAFT AND CAN NOT MOVE. THE FORKED
END OF THE VALVE ACTUATOR LEVER RIDES ON IT, HELD
IN PLACE BY THE SPRING ON THE VALVE-STEM AND THE
CRANKSHAFT BEARING.(BEARING NOT SHOWN)-THERE
IS A SHOULDER ON THE "VALVE ACTUATOR BUSHING"
THAT KEEPS IT FROM MOVING TOWARDS THE FLYWHEEL
IT SHOULD READ
VALVE ROD SPACER (SPACER NOT SHOWN)-THERE
View attachment EXPLANATION OF HIT AND MISS CAM ACTION.PDF
great post Brian :bow: looks like a lot of work went into them there plans, when dose the build start? ;D
Rob
Well, actually it started about 15 minutes ago. I went over to see one of the companies that fabricate custom machinery for me this afternoon, and put a big whine on them about the high cost of aluminum, sob, sob. ---So being the great fellows that they are, and seeing as how I've put about $28,000 worth of work thru their shop this year so far, they let me go out back and launch a full scale raid on their "cut-off" bin. I came home with a big cardboard box full of about a zillion dollars worth of aluminum, and just started work on the cylinder.
Great stuff Brian ,there is nothing like a Zillion Dollars worth of stuff for free :big:
Hope to see lots of photos ,Thanks for sharing your drawings
Rob
