Tel---As I dig deeper into this engine, it appears that there are three distinctly different springs that do different things. (Hey, that rhymes!!) There is a spring in the cylinder head that operates the exhaust valve slug, there is a spring buried in the mechanism of the governor to return the weighted arms to the "parallel to crankshaft" position at low RPM. And a third spring which has the function of #1--keeping the intake valve seated, and also #2 keeping the fork which is activated by the "cam" seated against the rotating collar of the dog clutch.---Right?
