Ehhh yes and no Mike. If he keeps a handle on the temperature rise, it won't be so bad
(Change in length) Delta L = Initial length x Thermal expansion coefficient x change in temperature
The CTE for stainless is 9.6 x 10-6 or 9.6/1000000 in/in/F
Another thing in his favor is the use of a DU bearing set. For the calculation above, the length of note is only the distance from the front of the bearing to the tip of the tool. The initial length is small...maybe 2" ? It floats behind that up the shaft.
Now the big question...whats the temperature rise?....keep that small and life is good.
Lets say its as I stated and the rise is 30F above ambient
Delta L = 9.6/1000000 x 2 x 30 = .00057"
Now that's from start up to full running condition. I very much doubt you will see that in operation as you will take a roughing cut and then a finishing cut, and the spindle will have warmed up by then and stabilized..it will have gotten to temperature and stopped growing by the time the finish cut comes around.
Now if it gets to be a lot more than 30F or 2"...well...then you may have a problem.....always wise to cool and control the temperature of a spindle.....wait till you have to do it with a spindle that has 8" in front of the thrust bearing! and your trying to hold s micron!
Greg,
I'll send you a balance worksheet for ISO1940....send me a pm with your email
