PROGRESS
I am slowly nibbling away at the noise problem and am learning quite a bit from the forum members and my own experimentation.
What I have learned:
I have isolated the spindle bearings and they definitely are noisey and I have replacements on order.
The motor is noisey too. I set up a fractional HP motor to just drive the spindle. It eliminated the motor noise, but not the spindle noise.
The idler stepped pulley has noisey bearings. If I am careful with the belt adjustments, I can minimize that noise. That is a major improvement.
Proper shimming and backlash adjustment in the feed change gears can make a big difference also.
So, progress. After I get the new spindle bearings installed and see what they do, I will attack it again.
Lloyd
edit..... The replacements are on order from Dublin Ireland, and should arrive in less than a week. They are a class P5, one quality class better than the original P6 bearings.
Lloyd
