This one uses pistons, not plungers, and huge ball check valves.
Amazing !! Sludge-Kat can pump 2.5" diameter nuts, bolts, and rocks!!
That thud sound you heard was me falling out of my chair !!
And wiki informs me that they even reach 400Bar(!) With hydraulic driven piston pumps. So probably a great place to start looking for designs.Concrete is routinely pumped many stories up, for constructing new concrete buildings.
Grain is moved by elevator buckets, but on the horizontal moved by screws, they can be a very dangerous system to be around. In waste treatment plants you can often find Archimedes screws. Spiral fluted pumps are used to compress products to a higher pressure. The spiral narrows at the exit point. The largest lift on an elevator I have seen was used in a coal mine. 400 feet straight up. For inert materials such as coal ash compressed air or vacumn systems are often used. Concrete can indeed be moved with a screw type pump but for high pressure piston systems are used. That is if you want to go a few stories up or seal off a oil well. Been around most of these systems. You can spend a great deal of time and labor dealing with material handling issues.I don't really know what I am writing about, but have a notion that slurries and grain, etc. are often raised very high to fill silos from the top - so the pressure of the column is managed by a screw pump?
My only experience of a "screw pump" was plastic and elastomer extruders in cable manufacture. But in those the fluid was melted plastic, or uncured elastomers. The work of the pump on the fluid actually raised the temperature - enough to melt plastics, etc., or for things like PTFE, etc. that do not melt, hot enough and with enough pressure to sinter the material.
But never anything with lumps of rock or nuts and bolts, etc.!
I always assumed concrete pumps were essentially Archimedes screw types...? - Wrongly it seems!
Hello, I also wanted to make a 350 bar pump that can pump viscous liquids such as diesel oil.English... Just use an online translator...
I see 400 bar... that's a lot. Is it for a diesel or something like a hydrostatic pressure tester?
Hello and where could I find the plans for the high pressure pump?I recently made a pump that should meet your needs; The build thread is here: Axial Swash Plate Pump.
I built two different valve designs,...the design using valve plates should work to pump diesel oil. The design using ball check valves will work with any liquid, but is harder to make all the parts.
I tested my pump up to 60 bar, which was limited by the power supply for the electric motor. You will need a larger, stronger motor than I used to reach 350 bar.
You should also be able to use a pressure washer pump like this one, Steller Pump. The price is about $40 US.
and a motorcycle oil pump would reach that pressureI recently made a pump that should meet your needs; The build thread is here: Axial Swash Plate Pump.
What kind of flow rates? 350 bar is a lot. Iirc Sulzer uses plunger pumps to pumps on their engines to develop that kind of pressure, and that's with much more viscous fuels.Hello, I also wanted to make a 350 bar pump that can pump viscous liquids such as diesel oil.
I'd love to download the drawing - - - but - - - - clicking on the file opens it.Can you use a CAD file? The drawing I have I made for myself, it is not 3-D and not fully detailed, but between the CAD file and all the photos I've posted, you should be able to duplicate my pump.
Please - - - some way to download it?
TIA
