nissan20det
- Aug 30, 2013
- 15
- 0
Hey guys,
Okay so this is my first engine build and i decided to make a scaled down 4" long SR20DET (Japan turbo 4cyl).;D
Now I'm working on the block, shaped, bored cylinders and cut out crank housing. I am now trying to cut my blocks main journals. Now i do not have a lathe or access to one. I'm using a Sieg x2 I only have 2 hand fulls of endmills a boring head and a 4" rotary table. now my first thought was to take 1/8 ball nose endmill find center cut a line .0625 deap and then mirror that on the girdle I have made. then when I mate them (there bolted together along with 2 dowel pins to stay true) there will be close to a 1/8in hole nice and center all the way down. then stand it up and jobber drill and ream it to .3760. now i think this would have worked fine although I spaced that the block is billet aluminum and the girdles some grade thats quite softer so as you can guess the bit walked into the girdle like crazy. so Damn!
Well the i thought ok lets give it a shot to take a 7/16 endmill plunge down(wile bock girdle still together) . k well this made it down 3 journals cool. then i figured ok well if i flip it no way ill get it centerd so popped in a 7/16 drill bit figured ok i have 3 journals to keep this bit from walking that should work.....NOO ughhh still walked
So then i tried .5 same way but higher drill speed slower feed and I got close but the bottom is still slightly off (not quite half and half circles) so. Then i tried making a boring bar. 3/8 cold rolled steel made an angled slot then put a HSS square bar in... Tried that and Just too much vibration really not cutting what so ever. AHH!! WTF:wall:
Soooooo, Im now at the point of these journals getting to big my bearings are gonna be big already. The next thing i try really needs to work to not have to scrap 15-20hrs on this block. Please feed me some ideas im open to any thing as long as its not use a lathe or go buy this $50-100 endmill/jobber bit
