Swifty
It's all coming together really well Gus, don't push yourself too hard to get it done by the end of September, slow and steady wins the race.
Paul.
Paul.
You are making great progress Gus. You may end up with the third running Rupnow engine!!!---Brian
Gus--Nice to hear from you. For the flywheel to fit without slipping on the 3/8" shaft, you need a full .002" interference fit. Anything less than that, it will slip. If you are making a two piece flywheel, then I would have to know the two diameters involved. At top dead center, there is about .129" from top of piston to flat inside cylinder head. The valve heads stick up into that "clearance" about .045". ---Brian
Gus--That figure of .002" interference was for steel shafts being pressed into brass flywheels. I'm not terribly sure if it would be the same for steel shafts into cast iron flywheels or not.---Brian
