Cogsy
Looking very nice Gus. I'm putting off the sideplates for fear of lining the bearings up properly, but I'll soon have no choice.
So how was the fishing Gus, fillets, steaks, or fillet steaks?
The build is looking good, measure twice and cut once is a good philosophy. When you can take the time, why not take it. Of course we are all grinding our teeth, waiting for the next part to the puzzle, so no rush.
Eddie
Going great Gus, once you have the cylinder and piston finished most of the hard work is done.
Paul.
Gus--If the piston is .002" undersized, it will still probably be okay. I always bore the cylinder, then hone and lap it before I make the piston. Then I TRY to make the piston .001 undersize. Its pretty subjective, trying to measure or machine anything to within .001"---for me anyways. If the machined finish of the piston measures .002 undersize, I would still carry through with the procedure of lapping the piston into the cylinder as outlined in my build thread. In reality, very little of the piston rides on the cylinder wall anyways. Up near the area where the piston ring is, you get virtually zero contact, because the piston ring takes all the contact and holds the piston concentric in the cylinder bore. The maximum contact area with the cylinder wall is down at the far end of the piston skirt, and that doesn't seal much of anything---it just serves to keep the piston from tilting in the bore.---Brian
