shred said:I'd think there's a limit or relationship to to how small a CNC cutter has to be and the DP of the gear to be produced by it.
As to your question yes, Wire EDMs can be used to create bevel gears, dependent on the size and distance of the taper, with abit ingenuity I've even cut helical gears on a wire EDM. The main things to consider when having any gear wire cut is the cost, a gear can take minutes or hours dependent on the thickness of the part,accuracy and surface finish.Dan Rowe said:Pete,
I have read a few of your posts on HSM and it is very clear that you know a considerable amount about gears and EDM.
My question is simple can EDM be used to make a bevel gear?
Dan
Dan Rowe said:My question is simple can EDM be used to make a bevel gear?
Dan
precisionmetal said:More gears...
Cut these for a buddy who is working on a ¼-scale engine project. Crank gear (the small one), 2 cam gears, 2 idler gears and 1 magneto gear. The two 1/16" holes in the cam gears are for driving the cam (only one hole will be used). He wasn't sure yet whether he wanted the drive hole on a tooth, or on a gullet, so I put in one of each. Those gears have 40 teeth, so the drive holes are 175.5° apart. The crank gear has a .250" bore with a 1/16" key. Since it wasn't possible to put a keyway in the gear, I just integrated the key into the part.
Gears are 64DP 20°, with the tooth thickness reduced about .0007" from standard in order to give each "pair" about .0015" total backlash. Material is A-2, heat treated to 55Rc.
Andrew Stewart said:The question I am asking is how does one decide what DP cutter to purchase.
