Looking good TonyM
Thanks Graham. Moving it one tooth was a bit too much and the exhaust was closing too soon. I relocated the exhaust cam and re-drilled the inlet locator. Got it to here now. Exhaust opens just before BDC and closes just at or very slightly after TDC. Inlet opens Just after TDC and closes at or very slightly before BDC. Compromised a little on valve lift.That’s pretty damn close Tony…. If you advance the half time gear by one tooth only you should get the exhaust to open just before BDC and see the air valve fully closed by BDC on the induction stroke. Otherwise it’s near perfect.
Very nice Tony.
There’s a cracking video on YouTube, released yesterday of one of ours. Some nice close ups of the governor. Running on LP Propane and gas ring heated, hot tube ignition.
Cheers Graham.
Feel free to join us at… Log into Facebook
You sure you're not trying to start a sewing machine? Looks like one.Thanks Graham. Moving it one tooth was a bit too much and the exhaust was closing too soon. I relocated the exhaust cam and re-drilled the inlet locator. Got it to here now. Exhaust opens just before BDC and closes just at or very slightly after TDC. Inlet opens Just after TDC and closes at or very slightly before BDC. Compromised a little on valve lift.
Tony
