ukanduit
- Feb 13, 2010
- 20
- 9
No, was it in Greenville Ohio?Did you go to the Greenville Engine show, two years ago? That is the year featuring Stirling engines.
kinda cool to see another Greenville native on hmem. It's a tiny cornfield blip on the map andI grew up on the other side of town. I now live in Texas , but do remember going plenty of times to the steam thresher reunion.
I am looking into possibly anodizing my current motor but will be a while before it's ready.
A few questions though, first - how dark can the part come out. And is it adjustable for varying sheens.
I would prefer a non transparent look similar to paint.
And how well does it hold up under engine conditions, meaning longevity and oil etc...
Also the clear, can it be applied to bare metal, say the outer flywheel ring, does it tend to yellow after a time as most other clears do.
When I set it up, I use a 6A battery charger. I set it for 12 volts. The positive is attached to the part, the negative is attached to the lead bar/plate/scrap. You can use a 12 volt battery for the power source. Once again, attach the positive to the part, attach the negative to the lead. Be aware that while this is working it is producing hydrogen gas so do it only in a well-ventilated place. I do it outdoors under a shed roof overhang.Gunner, is the battery used for both stages? How is it hooked up? You mentioned lead as the negative - is the positive directly connected to the piece being anodized?
