josodl1953
Hi there!
Following my thread in the welcome section, I started to explore the possibilities for the build of the Forrest Edwards radial, in a slightly downsized version. As explained in the aforementioned thread, I intend to use some bike hub gears for the cam drive. In order to see if this works, I made a mock-up withe some scrap metal to chweck the center distances of the gears.Now there is a problem when downsizing this engine, I intend to downsize to 80% of the original size. The shaft of the idler gear in the original design is supported at one side only, in the crankcase. I want to fit the idler gears on a shaft, supported on both sides withe miniature ball bearings.I put it al together and it works rather nice, no excess backlash and no binding.[/ATTACH]
So, up to the next step.I will make a wooden model to get an idea of the size of the machine and to try some design changes.
To be continued....
Jos
To be continued....
Jos
