My math is off somewhere.
Somebody help me.
Seems like you are mixing your units.My "Hansen" Diesel has a stroke of 40mm, and a head space at TDC of 2mm, so ~20:1, diameter doesn't factor in, its that simple !!! (technically its 42:2, but 40:2 is close enough for gov't work !)
Hello, I would like to know if there is a formula to calculate what diameter and stroke a diesel engine should have with a compression ratio of 20 to 1 or with a compression value of 25 bars.
I use the mass function in Solidworks to calculate the mass of various 3D parts, so I can calculate how much metal I will need to cast a part.A function in 3D drawing software allows the calculation of a volume, hence it is easy to model the combustion chamber to determine its volume, even for a complex shape...more easy than measuring it with a liquid, particularly if the engine is not yet built!
Hello Rubin,Hello, I would like to know if there is a formula to calculate what diameter and stroke a diesel engine should have with a compression ratio of 20 to 1 or with a compression value of 25 bars.
