That reminds me, I forgot all about digging out the drawings. To give you an idea, the bevel gears are about 3/8" diameter, and yes, I cut them on the Myford - hand planing with the topslide
Tel--If you can drag the drawings out and post them or email them to me, that would be just great. What kind of steam/air supply valve did it operate??--a sliding valve or a butterfly valve. Did you find that it was effective and actually governed the speed of what you were running with it?---Brian
Brian, please tell me where you found the dimensioned drawing of the governor.
There is a story here- I have that drawing somewhere in one of my books. When I was doing the first show flyer for the New England Model Engineering Society [url]www.neme-s.org [/url] I found it, scanned it, and used it in the flyer. It later became essentialy the logo of the club- its on our Shirts, our show banners, newsletter and Ive even made engraved name plates several of us use at shows.
I want to make a model of it, but I can only find the scanned drawing, from which I stripped the dimensions to make it simpler for the logo.
Thanks for posting the link to www.neme-s.org. I have been over there for several hours and I know that I have barely scratched the surface. Steam, all types of engines and tractors, machinery, antique tools, Jet model aircraft any many many more. If anybody hasn't clicked on it yet I would advise them to if they like that type of thing and I think most on this forum do. I know that I have book marked it so that I can go back.
Tel---A question for you. Did you find the flyball governor which you built to be effective in governing the speed of the engine which you put it on. And--how many cylinders was the engine it was controlling, and what bore and stroke?--A lot of questions I know, but stuff I need to know before I embark on a build if I make one of these for myself. Thanks, Brian
Well, yes, the governor worked quite well, but as I said, I did simplify the innards of it - just a simple plug moving up & down in a bore and covering, uncovering, the steam passage.
The engine in question is Jesse Livingston's Rocking Valve Mill Engine - 1" bore, 1 1/8" stroke - the cylinder on the is quite a compliacted piece, and was a lot trickier to fabricate - still, the finished product was well worth the effort.
Here's a couple of pics before and after silver soldering the fabrication, but befor clean up. Them porcupine quills are little bits of 1/16" brazing rod that were used to hols everything together and got cut off and disappeared during clean up.
While we're on the subject of working governors - here's another one I did, copied from an old illustration (engraving) of the Ames Automatic Cut Off Engine - it also worked a treat.
Look what I found!!! This is a casting kit by Art Dekalb in New York. It comes in two sizes, one with 3/8" balls and one with 1/2" balls. of course the one in the picture has been fully finished, but Art only sells the castings, apparently. I am currently wheeling and dealing with him, trying to get price and delivery.---Brian
You got it Brian - 'cept you didn't show the spring!
Now picture the end of the spindle carrying a piston of slightly larger diameter, working in a bore to cover the steam inlet as it descends from the action of the balls. Much simpler than the version I sent you, and the way I did mine.
Tel---I didn't forget the spring.--Its just that springs are a miserable thing to model. I just got an email from the guy in New york. His "Kit" sells for $20.00 U.S. plus $4.50 handling. Seems like a reasonable deal to me. He said that they come complete with sets of drawings. I don't see the brass balls in his "Kit" and I guess the shaft and gears aren't there either. If I don't have any real work tomorrow (which isn't looking too probable) I will go ahead and finish my design. I have a design here for the governor used on a Stewart model, which has no gears, just a pulley on the bottom of the ball bracket. It is driven by a 90 degree twisted belt off the main driveshaft, which would be ideal to work with my horizontal twin that I just finished.
