Rdean---isn't is funny how another persons ideas can influence an entirely new train of thought. That happens to me a lot. I've always maintained that I can design anything, but the real trick is thinking of WHAT to design.---Brian
How fast are you feeding? A lathe that size should be able to handle more than that, unless your feed rate is way too high. For reference I run my Southbend clone at 50 thou DOC when roughing, and would usually feed somewhere around 6 thou per rev on steel. With carbide I usually just crank the spindle up as fast as the (1hp) motor can drive it in the cut I'm doing. I generally run out of torque before the carbide is even breaking a sweat.I can only manage about 0.015" depth of cut. Of course that takes 0.030" off the diameter. Running at 700 rpm with carbide cutting tool.
