Well done Dean.
I just wanted to add that like every type of tool, get the best you can find and afford, they are life long investments and will last if properly maintained.
I use chalk (kids sidewalk chalk) on my files. I have two small files I keep on the lathe for the purpose of breaking edges and simple deburring and they generally have some cutting oil on them but I don't go out of my way in that respect.
There has been mention of filing buttons and filing rests but no pictures. Filing buttons are very handy for filing round corners on things and are nothing more than rounds with a hole in the middle that are bolted into a hole near the corner and used to guide the file. Filing rests are frequently used on lathes and you will find lots of reference and pictures of such devices in use on small jewellers size lathe (but also on larger ones too). A quick Google search will bring lots of results for filing rests. It amazes me the ingenuity of those who work with their hands and the excellent results that can be had with the simplest of tools.
I use files a lot. I don't have a mill and even if I did I would probably grab for a file to do a simple job in 10 minutes than spend 30 setting up the mill. Draw filing is something I do almost every day - cross filing to rough into shape, draw filing to level, smooth and prepare to finish. Sometimes the finish left from draw filing is sufficient.
I have attached a couple of photos that show some work done to a cheap import surface gage. The gage was usable in it's purchased form but was rather rough. I am in the process of cleaning it up. First job today was to clean up the adjustment/mounting arm. It looks like this piece is made of cast iron or flame cut low carbon steel and very roughly finished. looks like it was deburred on an off hand grinder.
First photo shows one side after a very quick draw filing to level it out and start the smoothing process. The remaining large void was the largest and deepest of the surface irregularities. This particular side was about 60% covered in similar large rough voids.
Second photo shows the same side after a rough finish draw filing and the third photo shows the same side after a quick lapping on 400 grit wet or dry and oil.
Total time: about 15 minutes
