Thanks Bob,
Almost done. Decided to do the crank eccentric a little different, mainly because I didn't want to use any of the 2" dia brass stock I had, the only material I had to make the 3/16 thick piece. A trip to Ace Hardware yielded two 3/8 dia brass washers at 38 cents apiece. That with the 1" wide x 1/16 brass bar stock I had in stock would work.
I milled the rough shape into the barstock then soldered the washers to it. Drilled and reamed to size, then made a fixture to locate on the finished dia and milled the finish profile.
Just need to clean it up and polish
