The chest looks good Gus.---Brian
I hate wood: too dirty, flimsy, shifts and changes after the job is done, dusty stuff ...
Much prefer the nice clean smoke and melt and grind experience,the brown chips, and the "it'll never split" of steel.
How did the drawers finish up, Gus?
Excellent work Gus. You seem to do all right with "the brown stuff". Very professional
Phil
I've done my share of wood work, my biggest problem is I apply wood work fits to my metal work projects. If you can find some scrap DIBOND/E-panel it would work great for dividers, drawer bottoms and the like, strong, easy to work with and light weight. Total 3mm thick, .012 aluminum over polypropylene then .012 aluminum. A sign shop would be a good place to find scrap. http://graphicdisplayusa.com/en/products/dibond/dibond/
Congratulations, Gus. One tip about spraying especially from spray cans is heat. We live in a fairly cold climate where the winter snows that came in mid November are still ringing the headwalls of hills and mountains. My neighbour at 75 is still getting a geriatric run or two in.
We've given up now- but I digress. I always put the spray gun or the aerosol into a bucket of fairly hot water at - each rest.
I spent a bit of time messing about with resins and plastics and paints in my youth( ????) and we used to do tests for paint/plastic viscosities with things like Ford cups and PRS viscometers which are really test tubes with oils that allowed a bubble to rise in a given time at a controlled temperature in a water bath- at a controlled temperature. Frankly, you'd be amazed at how little temperature change to affect the flow of a liquid- and the work.
So I'm watching carefully the temperature before I repair a scratched front wing/fender on the Audi A4 Avant. Silver then clear over base.
Enjoy the fishing, eh?
Norman
Gus
I love what you did with a little wood. I was wondering to start with and I figured I would continue to watch. You have done a very good job on the box and take pride in it because you did not need bondo to make it look good. Some say that wood has no place in there working, but I tell you all that wood just like metal can be very satisfying. Carpenters work within a quarter of an inch, Cabinet makers work within a thirtsecondth, and a Machinist works with in thousandth.
The nicest thing about a wood box is it can get cold and humid and you will not find RUST. Gus, very nice.
Nelson Collar
