DIY Tesla Impulse Turbine
OK, I ran the numbers on my tiny DIY water pump first using the simple equations Gemini (Google’s AI) found, and then using the step-by-step equations described in the link you provided. The results from Gemini's equations are more-or-less reasonable, but the results from the Euler’s turbomachine equations are pretty crazy.
From Gemini:
Q = π * D * B * ω / 60 = 3.1416 * 0.04878 * 0.012 * 120,000 / 60 = 3.678 cubic meters per hour
= 61.3 LPM which seems reasonable.
Using the results, 3.678 m^3/hr, and the somewhat ridiculous pressure obtained from the Eulers Turbomachine Equations, plugged into the power equation found via the internet, results in the following.
Power (kW) = Q* P * SG / 3600 = 3.678 * 480.6 / 3600 = 0.49 kW
The need for 1/2 kW to power my small pump also seems reasonable.
____________________________________________________________________________________
Euler’s turbomachine equations:
Given:
diameters of the impeller at the inlet and outlet
r1 = 0.01374 m
r2 = 0.02439 m
Speed = 120,000 rpm
the blade angle at inlet β1 = 30°
the blade angle at outlet β2 = 20°
assume that the blade widths at inlet and outlet are: b1 = b2 = 0.012 m
First, we have to calculate the radial velocity of the flow at the outlet. From the velocity diagram, the radial velocity is equal to (we assume that the flow enters exactly normal to the impeller, so tangential component of velocity is zero):
Vr1 = u1 tan 30° = ω r1 tan 30° = 2π x (120,000/60) x 0.01374 x tan 30° = 99.6 m/s
The radial component of flow velocity determines how much the volume flow rate is entering the impeller. So when we know Vr1 at the inlet, we can determine the discharge of this pump according to the following equation. Here b1 means the blade width of the impeller at the inlet.
Q = 2π.r1.b1.Vr1 = 2π x 0.01374 x 0.012 x 99.6 = 0.1 m3/s = 6000 LPM = 100 L/s
In order to calculate the water horsepower (Pw) required, we have to determine the outlet tangential flow velocity Vt2, because it has been assumed that the inlet tangential velocity Vt1 is equal to zero.
The outlet radial flow velocity follows from conservation of Q:
Q = 2π.r2.b2.Vr2Vr2 = Q / 2π.r2.b2 = 0.1 / (2π x 0.02439 x 0.012) = 54.38 m/s
From the figure (velocity triangle) outlet blade angle, β2, can be easily represented as follows.
cot β2 = (u2 – Vt2) / Vr2
and therefore the outlet tangential flow velocity Vt2 is:
Vt2 = u2 – Vr2 . cot 20° = ω r2 – Vr2 . cot 20° = 2π x 120000/60 x 0.02439 – 54.38 x 2.75 = 306.5 – 149.5 = 156.9 m/s.
The water horsepower required is then:
Pw = ρ Q u2 Vt2 = 1000 [kg/m3] x 0.1 [m3/s] x 306.5 [m/s] x 156.9 [m/s] = 4,808,985 W
= 4,809 kW
and the pump head is:
H ≈ Pw / (ρ g Q) = 4,808,985 / (1000 x 9.81 x 0.1) = 4,902 m
= 480.6 bar
= 6970.5 psi
These results are laughable. 4,809 kW turning the 8 mm diameter stainless steel shaft seems likely to sheer the shaft, assuming the aluminum impeller didn't self destruct first, and that the Tesla turbine could actually produce that much power. It all seems most improbable.
I suspect what these numbers are telling me is that there's simply no way my tiny water pump will actually spin at 120,000 rpm.
Testing the Tesla turbine and using the water pump as a load should prove interesting :cool:
The reason it's like this is your ludicrous pump impeller tip speed from the high RPM of the tesla turbine. Honestly this is kind of the problem for most single stage turbines, they want to spin way too fast for most loads aside from turbocompressors and electric generators.
What will happen is that your pump will load the turbine down to a speed where the driving torque demand of the pump matches the output of the turbine. Obviously not ideal for turbine efficiency. You will probably find the pump outputs a lot more pressure and flow if you gear the turbine output down so it's running at a more optimal speed.
Edit: for reference, your tip speed seems to be slightly over 300 m/s. The LOX turbo pump on the F-1 engines of the Saturn V moon rocket was only running a bit over 142 m/s.
I did a bit of Googling and found that covered impellors are used up to 360 m/s, and open impellors, like mine, are used up to 500 m/s.
From what I was able to find, it seems max tip speed for water pumps is limited by material strength of the impellor; 50 m/s for cast iron impellors and 110 m/s for stainless steels. I have no idea what materials manufacturers are using to reach 500 m/s; perhaps the difference is simply which safety factor is used.
I strongly suspect the Saturn V LOX pump tip speed is limited primarily by the material strength of the impellor, which is pumping a liquid with a temperature of -183 C, which makes all metals very brittle.
That's where copper-nickle alloys come out to play.
Forgive my memory, where does the air blower go?
The centrifugal air blower (aka leaf blower) blows fresh air into the combustion chamber.
A separate swashplate air pump supplies 3 to 20 psi air pressure to the venturi effect fuel nozzle.
Sorry, I thought the end goal of this was to use the whole thing to run a blower? Like a massive steam plant leaf blower?
Hi Toymaker.
I have been a bit of a "Doubting Thomas" for your combined impulse/surface friction turbine, because it seemed to used conflicting rather than supporting technologies. But reading part of a paper (by some German clever bloke) There is a summary table of various experimental works of note:
CHAPTER 2. PREVIOUS RESEARCH ON TESLA TURBINES
Table 2.1: Selected performance data of previous Tesla turbines. Maximum power and maximum isentropic efficiency data is usually achieved at different operating points:
I noted that the turbine by The turbine by Steidel and Weiss [1976] is different in that the outer disk edge is not circular but has several sawtooth-shaped cut-outs.... and thought 6.7% efficiency was "not so good" - But then I read more and it seems that Lisker et.al. achieved 38% efficiency with "another rare design feature is found in the turbine by Lisker et al. [2015] who add blade inserts to the outlet region of the disk gap, essentially building a hybrid between friction and bladed turbine".
So obviously you are on the right track, Well done!
P.S. file to large to paste: try searching for "Design Guidelines for Tesla Turbines Based on Comprehensive Theoretical, Numerical and Experimental Investigations. Stefan Günter Klingl, M.Eng."
I think those higher speeds are for compressors. Gases being less dense than liquid put less stress on the impeller
You are correct :)
As to where the blower goes,...the air blower will be powered by one of two different steam driven turbines.
Depending on how successful my Tesla-impulse turbine turns out to be, I will either build a larger one, matched in size to use the max steam output of my boiler, or scrap the Tesla-impulse idea and use the 3-stage axial flow turbine I've already constructed. I used very standard design practices to construct the axial flow turbine, and I therefore have a high level of confidence it will work well,...BUT because it only has 3 stages, to get the most efficiency from it, I will need to use a Freon such as R123, as the working fluid, instead of water.
For me, the biggest advantage of using a Tesla turbine, instead of an axial turbine, is that a Tesla turbine can efficiently use water as the working fluid. As an added benefit, Tesla turbines can use wet steam without the corrosion issues seen in axial turbines, so, no need to add steam dryers, or water separation devices.
I had the same thoughts initially, that surely the higher tangential speeds were for impellors pumping gases,...but on second thought, I couldn't recall ever seeing a closed centrifugal impellor used for gases, and multiple articles cited the 360 m/s limit for closed impellors.
Hi Toymaker.
Thank you much for finding this info :),....very encouraging !!
But now I don't know whether to be happy that I'm likely on the right path, or sad, that I'm not the first crazy person to think of this idea.
