DIY Tesla Impulse Turbine
Well, that's not good,... as I suspect the stainless shaft will always rise to at least 100° C.
The next test run will be interesting,...I replaced the melted spider with quick-set epoxy, essentially making a replacement spider using epoxy. If this too fails, I will use either a high temp epoxy or high temp silicone.
I wonder if high temp rtv gasket maker might work?
