ajoeiam
- Aug 14, 2020
- 1,040
- 307
Regarding thermal expansion, I think it is not a problem because With 4 pumps and 4 injectors only 1 injector does not seal when the temperature is increased.
I think there's a problem with the way I make the injectors
Hmmmmmm - - - - before you go down the road to "the way I make the injectors" - - - I would suggest that you very very carefully measure your injection pump. You might find (have to measure to at least 0.0001" (0.002 mm)) that that one problem port that your body is either a tiny bit larger or the internals are a similar bit smaller. Commercially this equipment is measured using air gauging - - - - and that's working to 0.000010" (0.0002 mm). This level of metrology is not simple nor easy - - - - temperature control is crucial (IIRC assembly area is controlled to +/- 0.5 C) - - - - one can't hold the parts in a bare hand and expect them to be able to be assembled - - - steel moves at 6 millionths of an inch per inch per degree F (sorry - - - memorized that way don't know the SI equivalent off hand), carbide is some 3 millionths . . . , aluminum moves far more - - - thinking something like 12 to 14 millionths if not more but check that one if you're using aluminum (Machinery's Handbook has tables for coefficients of expansion (pgs 369-370 25th ed) .
Building one's own injection pump means that one must work to the tightest tolerances - - - yes there are tighter but not for somewhat common items. So I wouldn't consider what you have done a failure - - - - rather the opposite. So please just check that particular section very very carefully before you pitch a very great (good) effort.
