Hi Everybody .
An update:
" You died in the game , you get a new life and continue game "
I made a new valve block, I decided to use aluminum because I ran out of brass. Using aluminum or brass as the valve block I think it doesn't matter
First valve block the holes are not concentric , I think it's a matter of making the valve sometimes closed and sometimes not , and I have also changed a bit .. and also positioned and drilled the holes more accurately...hopefully this time will be good enough .
An update:
