Hi All !
An update:
Injector - First test:
I can't get it to inject fuel, the fuel just drips. , with many adjustments and tightening ( because I think it's not sealed ) so part of the injector is broken . After measuring and checking...I found that the inside diameter of the needle body fit well and that caused the needle to not move freely, so I changed it a little with the inside diameter - as shown in image
Second test: After checking everything is ok, but it still doesn't spray in the form of fuel mist, adjusted dozens of times still doesn't work.
Then I thought "maybe it's the test fuel", it's old oil and it's a mixture of diesel and quite a bit of w40 oil.
So I changed to just using new diesel, and after a few tweaks, the result :
