Anatol
I found this page a while ago, seems useful, I wrote to the author but communication petered out.
I have just been looking at a site from Cornell University, http://kmoddl.library.cornell.edu/resources.php?id=113 that has mechanical models and explains them with math equations that are way over my head.
. I try to keep the dead area to a min and have tried a little overlap on the exhaust and find they run a bit better
What's the reason for the compression region?
The purpose of compression in addition to the steam pressure emitted into the cylinder a bit earlier before TDC, we utilize the steam as much as possible when the steam expands in a closed cylinder. The purpose is reduced steam consumption and better power out of steam engine.
The wobbling steam engine is a poor economy in steam consumption and difficult to get more power out of wobbling steam engine due limited by spring who are holding the cylinder to valve plate.
Once the inlet opens, the amount of steam admitted depends on difference between steam pressure and cylinder pressure, so having increased pressure from compression reduces the amount of steam admitted to the cylinder.
I'm afraid I still don't understand the compression purpose - it uses engine power (from steam of last stroke) to compress air before the inlet opens. Once the inlet opens, the amount of steam admitted depends on difference between steam pressure and cylinder pressure, so having increased pressure from compression reduces the amount of steam admitted to the cylinder. So in my mind it uses power, then restricts available power as well. It seems very inefficient to me.
You may find this usefull for what you want to do , I did
Don
