I know that this was a tiny bit "hokey", but only a tiny bit. I would probably grind my own hss cutter instead of using the carbide, as I can get a much cleaner, better defined cut with hss. Secondly, the "part" would normally be made from steel rather than aluminum if it was for a "real job". However--I was only attempting to go thru all the motions and set-ups required to cut a thread. Everything works, and seems to work very well. It is a bit of a steep learning curve, but there is a lot of information "out there", and the biggest challenge really is learning how to interpret the change gear chart. Thank you to everyone on the forums who helped me. I'm not sure I will ever cut more threads. For what I do, taps and dies work quite sufficiently. I just wanted to be able to say that I have cut a thread on my lathe successfully, and now I have.----Brian
