Hi all, back to the subject.
I have all the parts machined and fitted now.
First i made the brass hinges from the flat bar stock.
First turn and tap the m3 stud.
Then mark and drill for the hinge pin hole.
Cut the parts off the end of the stock and file the corners round.
Next cleaned up the door casting with a file and drilled for the door handle and hinge pin holes then tap m3 for the door handle.
Then i made the door handles from 3mm brass bar.
First turn and thread m3 then part off to length and round off the end.
Then aneal the parts before bending.
I use a bar with an m3 hole dilled and tapped in the end to hold the part and use pliers to bend.
Then fit the handle and door hinges and pin.
And thats all the fabricating and machining done now.
Tomorrow i will clean and paint the boilers and fit all the shiney brass bits.
Best regards.
Luke.
