Ispect joints are good all around..
Then onto soldering the boiler bushes.
Clean the bushes then apply flux to them all and all previous joints and on the boiler holes.
Use some fire bricks or steel bars to support the boiler and insert the first bushes. I just use two wire rods with hooks to repostion the boiler when hot. Or an old angle scribe..
Now heat the whole boiler untill the flux melts then keep the tourch fixed on the bush to be soldered, then move it slightly to the side as you dip the solder on the oposing side it shoukd wix around to the heat.
Check the sight guage bushes are in line, a little tap wile hot to straighten if needed.
Let cool for a few seconds Then repostion to the next bush. Again just keep the heat on the bush area.
If you put plenty of flux around the hole before heating they shoukd still be free from oxide and the bush with its load of flux is placed in while still hot.
Then stand the boiler up and place the top extended bushes into position..
Again just local heat with the torch and a quick dip of solder is all it takes.
A handy way to use shorter peices of solder is using a drill pin vice to save burning finger tips..
And the boiler after soldering, again quench while hot then back into the acid.
And the finished boiler after some pickle and polishing..
Next page.
