After looking over your beautiful stuff, I want to re-do some of my stuff on the same Corliss. One thing I thimpfk I absolutely must re-do is the Throttle Body. This is Stainless and difficult to do. I did one but would like to redo it as I have learned a little since then and I needs two anyway.This are the exhaust and intake ports. Here comes the rotatives valves
LeZap
View attachment 122771View attachment 122772View attachment 122771View attachment 122772
Great work, I absolutely love seeing Schaublin equipment of any type, loved that brand from first one I saw, beautiful stuff !Nice workshop & work.
I realy like your machines. I,m a fan of Schaublin. I used Shaublin when I worked as a toolmaker in1970.
On my Corliss, I redesigned the parts in this last photo. For the live of me, I could not figure out why the bases of these steam/exhaust bonnets were made in two parts. The only thing that comes near to the necessity is putting part 37 in your section view into the base part. However, that fits nicely thru the side opening just fine--so why the two parts? If anyone knows, please let me know.And the bonnet and valve port cover
LeZap
View attachment 122815View attachment 122816View attachment 122817View attachment 122818View attachment 122819
I understand completely however, I am of a different mind. I want the same results, the same look but if two parts can be made into one and still get all the other parts into it properly, to fit correctly and to operate correctly, then I consolidate them@Richard Hed : It's alway possible to simplify the original design, but I want to keep the spirit of early 1946. Thanks to Eloda Ray.
LZ
Beautiful L and RH threadsNow the gear and rods of the Corliss system
The third picture is the Schaublin spherical turning apparatus.
And of course, left and right tread.
LeZap
LeZapView attachment 123072View attachment 123073View attachment 123074View attachment 123075View attachment 123076
Nobody for the explaining?Can someone please explain how the exhaust valves closes?
Thanks LeZap
It is rather straight forward how it works.; The only snag is getting the valves in the correct configuration, both L and R hand valves. the opening is a bit larger width as well as the angle compared to the steam valve. Have you got those correct? It's very tricky. the valve has to be carefully timed when you tighten the bolt into the exhaust rod. The arm that the expansion of the top of the exhaust rod "clamps" to is attached to your wonderful adjustable connecting rods which in turn go to the rocker In the center of the cylinder. I notice in your parts that your steam and exhaust rods do not yet have the bored, threaded and split ends which you need. I have put a jpeg in showing the end. I hope this helps but if not let me knowNobody for the explaining?
I don't understand the problem. The exhaust eccentric operates the exhaust lever, this lever is connected to the first or right hand valve, operating it. Then this RH valve is connected to the center circle which operates the LH valve. The only thing is to make sure the correct valve is in the proper position and to make sure the valves are machined correctly.@Richard Hed, The four rods are finished, but the split have only 0,3mm (0,012") thick, so not visible but it work very well;
I understand (more of less) how the Corliss work. But to adjust all the parts together it's another song!
But I don't understand how exhaust valves closes. For the opening, it's clear.
There no fix link, only the dashpots at the end, but completely free
LeZap
Are you sure we're talking about the "exhaust"? The dashpots help operate the "steam" input not the exhaust. The exhaust is very straight forward, the steam input is more complicated.@Richard Hed, The four rods are finished, but the split have only 0,3mm (0,012") thick, so not visible but it work very well;
LeZap
