When I started drawing this up, I had a start at fabricating the bedplate from stainless steel, with upper and lower plates, with columns between them that were slotted to accept the webs. I gave up on that idea pretty swiftly as it was a complete pain in the proverbial and would take an serious amount of heat to even start to solder, not to mention the distortion. that's why the project never really took off until Pete put me in touch with Dennis of Historic Models and Reproductions.
The website you've quoted is who a lot of us tried to obtain castings from but struggled to even get a reply from. It is based on the same engine, but with some differences, such as the split cylinder block you can see in their photos.
Dennis email address is :-
http://www.historicmodelsandreproductions.com/
I would like to stress again that I've no financial interest in this; we're just working together to get this model back to life. And he's a top bloke too
Here's some more progress on mine - the rods have been bored and profiled in line with the bores, and then turned through 90 and the slot for the piston rod profiled. The first roughing op on the piston rods is underway from some 25x50 316 stainless, to bring the rod down to 11mm initially, plus I'm pushing on with a design for a thrust box for them, which Dennis is going to cast, and may even be of use to owners of Stuart & similar marine engines to help put them into full marine use.
