Clough42 ELS upgrade for Weiss WBL250F Lathe
Arizona, USA
I've had it working for several months with the servo motor hanging out the front, with pulley cover off.
The last couple of days I spend relocating the servo motor so that I can put the belt cover back on.
I was able install the ELS with minimal modification to the lathe.
Drill and tap two M4 tapped for encoder bracket, trim a little off the belt cover to clear the servo motor bracket and cut a bigger hole for the display.
I was able to test the ELS speed measurement system with the old tach in place as a sanity check. Both read exactly the same.
1/ Encoder is driven by a GT2 belt and pulley arrangement, with a 1:2 ratio. 8192 pulses per spindle rotation.
2/ Encoder spindle pulley is 120T and is split and 3D printed from PLA.
3/ Encoder pulley is 60T printed from 3D printed from PLA.
4/ Encoder bracket is 3D printed from PLA.
I think the rest of the installation is self explanatory. Mainly pieces of scrap mild steel and a few metric screws.
The servo to leadscrew belt drive is 1:1 and the gearbox is set to 2:1.
The servo motor just fits in the hole in the headstock casting with room for cooling and maintenance.
I will probably replace the encoder 3D printed 60T pulley with an aluminum one.
I have also ordered 24T and 72T pulleys for the lead screw drive, in case I need more torque.
No issues with the controls. No noise or unexpected behavior.
I also have a Clough42 ELS on my Taig 2 lathe. That was a little more effort because I had to add a leadscrew and split nut.
A fun project. No more greasy fingers changing the gears. and a lot quieter.
